scamanderriver
Hi
looking for help here to solve an issue I'm having ... (another big learning curve happening here)
I am trying to send data from the PGM editor (using the terminal via the serial programming cable) to a 40x2 using the SERRXD command.
using the below code it works fine within the Editor Simulation, BUT!!
when i send to the 40x2, problems occur
if i send 1 the LCD displays 49 which appears to be the lcd dec code for 1
if i send 12 the LCD displays also 49
it seems i can only send/receive the first digit(1) and that it is always received/displayed as the character dec value 49 (2 = 50 etc)
I don't understand what is happening, I need the 40X2 to receive and correctly display the full number 12.
I'm wondering if the issue here has something to do with "uncompressed BCD usually implies a full byte for each digit, whereas packed BCD typically encodes two decimal digits within a single byte"
I would be grateful if someone could please offer me an explanation to what is happening here. it'd be great to solve this.
Thanks
Thanks
#PICAXE 40x2
disconnect
START:
'loops waiting for input from PC
SEROUT d.1,N2400,(254,1) ' Picaxe 16x2 OLED LCD
serrxd [2000],b10 'input from PGMing editor via serial port
if b10 <> 0 then : goto show :endif 'show the received i/p
SEROUT d.1,N2400,(254,128,"waiting ",#b10)
pause 200
goto start
SHOW:'displays received number
SEROUT d.1,N2400,(254,128,"received ",#b10)
pause 200
b10 = 0
pause 2000
goto start
