Problem Programming PIC 08
Dermotx
I know this is a common problem which has been dealt with on the forum before many times but I’d really appreciate any help you could give me with programming a PIC 08 chip. I've read as much as I've been able to find on the forum about this problem and I hope I haven't missed something obvious. The equipment I’m using is all bought from Tech Supplies; an AXE021 proto board kit, serial cable AXE026 and the Picaxe chip PIC 08 (12F629). I am also using the latest Programming Editor software version 5.3.1.
When I connect up the cable to serial port on my PC and connect the 3 x AA battery pack (giving 4.84 V) I get the following error message with the 5 possible reasons for the error:
Error- Hardware not found on COM1
I am using a PC with a serial port on COM1. Operating system is Win XP with service pack 3, with 4 GB RAM and Intel CORE DUO 2.66 GHz CPU.
I have used the kit before to program a PIC 08 and had absolutely no problems. I lent it to a person who connected a 9v battery to the kit and of course blew the chip. He says he just replaced the chip and it worked fine when he connected the proper power supply but I'm not sure that can be believed. I have of course replaced the chip and I’m not sure if this could has anything to do with my current problems.
As I have said I have searched the forum and read all the articles dealing with this problem but I still must be missing something. Here’s what I’ve done to try and fix the problem.
1. I checked in my Device Manager to see if there was a problem with COM1. No problems reported and “This device is working properly” appears in properties.
2. Under Options in the programming software under Serial Port I’m getting COM 1 Serial Port ready for use. I then tested the port with the following results:
the voltage between the PICAXE serial input pin and 0V (leg 2 and leg 8 of chip) was -0.562v. When I clicked on the green LED the voltage changed to +5.46v.
I’m hoping this means that there is nothing wrong with my PC and that the problem is with the cable or the proto board. I should add that I tried to program the chip with a laptop as well and had the same error message. The laptop had Win7 and I used the serial to USB adapter which I got from Tech Supplies also. I also tried it on an older laptop with a serial port and still no luck.
3. I then checked the serial cable for continuity according to the pin out diagram which was available on the forum and there didn’t appear to anything wrong there either. That seemed to rule out the cable.
4. I checked the proto board as best I could (see attached photo) and while the soldering wouldn’t be considered great there was continuity between all the tracks and I checked that the solder joints were still making good electrical contact.
5. I bought a fresh supply of PIC 08 chips from Tech Supplies just in case I got a bad batch before or in case I mishandled them. Still no joy.
6. I tried resetting the chip by disconnecting the battery and downloading the program and then reconnecting battery etc as described on the forum.
7. Lastly I made sure that the jumper was in the correct programming position.
I presume the way to tackle this problem is by a process of elimination. I would like to eliminate the PC in the first instance. Is there a way I can do this?
Thank you.
Dermot
It sounds like you've done everything right and it should be working. Perhaps try with new batteries in case these read okay but have little 'oomph' in them.
If your friend replaced the PICAXE and had it working he could well be telling the truth, as the new 08's should also work which suggests it's something other than a faulty chip issue. I cannot see what though, and will have to think on - everyone else feel free to make their suggestions.
One thing you could try is taking the board to your friend and seeing if you can get it working together. If it works there it may reveal or narrow down the problem.
Dermotx
Hi Hippy,
Thanks for the reply. I changed the batteries and still no luck.
Here's what I did today: I have an old laptop that I used to program the 08 before and I re-installed Win XP (with just Service Pack 2) on it and the original version 4.1.11 of the Programming Editor software.
I tested all 5 new PIC 08 and ONE of them worked!!! It accepted the program.
I then brought the whole kit to my PC and connected it up with this now known good PIC and it still wouldn't accept the program. I brought it back to the laptop and it accepted the program.
This as far as I'm concerned looks like voodoo and I'm just going to have to buy a new cable and new Proto Board kit. There's obviously some intermittent problem which I can't find and I don't want to spend any more time on this.
I presume that the old serial cable is a better bet as it is less complicated than the new USB cable which appears to have some circuitry in it. What would you think?
Thanks again for your help.
Regards
Dermot
You don't at any point say you've tried a new set of AA cells - they may be flat (don't trust a multimeter reading straight across an unloaded set of cells).
Dermotx
Hi guys,
Problem solved at last! Well maybe not solved, but I'm able to program my PIC 08's again.
I put together my own programmer using a cable from an old serial mouse, a piece of stripboard and new resistors. I soldered the three wires from the COM port directly to the stripboard thus eliminating any problems there might be with the stereo socket. Who knows, maybe the stereo socket was the problem? I don't know, but I'm sure glad it's over.
Thanks again to Hippy, Technical Support and WestAus for your input and suggestions.
Regards
Dermot
Sounds like there might be an accidental solder bridge around the download socket on the AXE021 - check carefully!
