Hello,
I'm investigating the possibility of maybe looking at the applications of perhaps doing something along the lines of this:
some background:
AES3 is a digital audio protocol. the long & the short of it is that it runs at 24MHz (max, dependant on audio samplerate) on a balanced signal cable. The signal is galvanicly isolated at each end.
There are some very nice Analogue to Digital converters that translate directly to AES3, with minimal circuitry. And there are some very nice digitally controlled audio preamplifiers (for microphones) out there.
The analogue & digital circuit design is not a problem, I know someone that is pretty awesome at this sort of thing.
What I'm wanting to do is inject a serial-modulated DC onto the AES signal, and recover this at the other end. Its one-way communications, theres no need for any feedback. its going to be designed that the AD will clip before the preamp. if the AD clips, it will show up in our computer or on the audio interfaces.
The 24v would be dealt with to provide Audio power for the mic preamp & AD analogue side, and digital power for a control picaxe, AD digital side & preamp. power consumption would be about 150mA.
I've attached a very bad drawing of what I'm wanting to achieve. The resistors are to use CMR to remove the balanced AES signal from the injection/extraction.
I know that there has been previous projects of model train control over modulated DC, and other power&spi over DC projects, but I've had a look around, and I can't find them.
Is this as simple as having a 24v DC supply, then using a transistor to modulate this from the USART of a picaxe and inject to the aes. then at the other end, using an RC filter to remove DC (and maybe a schmitt trigger) to feed the picaxe USART, and a clamping diode (or similar) to remove the serial from the DC power?
some background:
