Not strictly a picaxe project as yet, but I need a solid state circuit that will switch on a 5v supply if the 240VAC it is monitoring goes down. I have a situation where there are a number of 240V feeds from separate trips and want to detect/alert if any of them trip. There are several trips I want to monitor, but only need a single 'alert' signal to say that one of them has tripped.
I don't want to use mechanical relays, I know I can do it with a transistor of sorts, but my transistor skills are pathetic so I need your help!
It's only to alert if one of the trips go, not the entire power feed, so in this instance there will still be 240V somewhere to power the 5V supply and pic.
Chris
Chris
