I have searched the forum But I haven't found an answer. I need a sanity check, as I am not confident in my limited skills.
I need to control a 3v3, 200mA load (ESP8266) with a Picaxe running at 5v using 3AA batteries and to make the batteries last for days I need to turn off the 3v3 load most of the time, turning it on only when needed.
I am trying to avoid using an always on 3v3 voltage regulator because it draws current even when idle, in region of 3mA (not sure whether it is just the on board LED). This is three times the current drawn by the rest of the circuit, excluding the ESP8266.
So I had the thought to instead use a eMOSFET 2N7000. I could drive it with the Picaxe and it would be able to cope with the required 200 mA. I tried it out and, when on I get a voltage drop of about 1.6V, so I wouldn't need the 3v3 voltage regulator.
Is this a good approach or am I going to run into trouble?
Many Thanks
Riccardo
Many Thanks
Riccardo
