stocky6409
Hi All
Still working on my little Xbee comms project ad am testing power scenarios.
Came across a little issue when the battery voltage gets very low.
The Picaxe 08m copes fine - but the Xbee tries to draw 50mA @ startup (before it can be disabled by the pin sleep mode).....which sort of stops the charging cct from ever getting the volts up enough to start the Picaxe which disables the Xbee......arrgghhhh
I have noted that if you hold the xbee RESET line LOW it doesnt "boot" and hence draw 50mA
so i think i have two options:
1) use a bigger picaxe with more i/o and switch the power to the xbee with the picaxe
2) some type of BOD or POR cct that holds the reset line of the Xbee LOW unitl VCC rises sufficiently.
The bigger Picaxe might be nice as a couple more i/o and freeing up an ADC lets me "self monitor" my battery status to limit power consumption during extreme low battery (ie disable xbee totally until chareg level improves).
Whats better at low voltage operation and low current consumption 14M or 20M?
Suggestions?
Stocky
Suggestions?
Stocky
