Can popup notification windows be substituted with a general notifications box? Optional so the popup window can still appear if you wish.
what I mean is any programming operation; uploading code to the chip or syntax testing results in a popup that has to be clicked on to get out of the way to get back to editing the code, if there were a general notifications box (with scrolling & time stamped notifications) this would eliminate the need to get the popup window out of the way so you can test & re-test syntax & uploading modified code to the chip and you can still see at a glance wether the operation was successful or not.
