playback switch
TheFunkyOne
Hello! I am using a 08m chip and have adapted code provided by chipwich for a $5 beatbox. I removed the powerdown stuff as I am attached to a powerpack, and changed the symbols back to their original meanings. The code works great, I am using peizos attached to sticks instead of LDRs. My question is: what is the best way to put in a playback switch: i.e. when pin3 = 0 then record, and when pin3 = 1 then playback?
here is the code as it stands. Cheers guys!
init:
start:
    high 0
    pause 500
    w2 = 0
    b10=0
record:
    readadc 1, b0
    readadc 2, b1
    b11 = 0
    if b0>20 then
        b11 = 1
    if b1>10 then
        b11=2
    'if b1>20 then
        'b11=3
    'endif
    if b10!=0 or b11!=0 then
savesample:
    b2 = b11
    gosub getsamplebyte
    if b13 = 0 then
        b11 = 0
    b2 = b2*b7
    b11 = b11|b2
endsavesample:
    b6 = $50 + b12
    poke b6, b11
    b10 = b10 + 1
    w2 = w2 + 1
    pause 20
    loop while b10<184
    low 0
findlastbeat:
    b8 = 0
    for b10 = 1 to 184
        gosub getsample
    if b11>0 then
        b8 = b10 - 1
    next b10
    w2 = 0
playsoundloop:
    b0 = 255
    b2 = 255
    low 0
    for b10 = 0 to b8
        gosub getsample
    if b11 = 0 then
    pause 20
    b1 = 0
    elseif b11 = b1 then
        sound 4, (60, 2)
    elseif b11 = 2 then
        sound 4, (100, 2)
    'elseif b11 = 3 then
        'sound 4, (120, 2)
    b1 = b11
    if b0>140 and b2>160 then
    readadc 1, b0
    readadc 2, b2
    w2 = w2 + 1
    next b10
goto start
getsamplebyte:
    b12 = b10/4
    b13 = b10%4
    lookup b13, (1, 4, 16, 64), b7
    b6 = $50 + b12
    peek b6, b11
getsample:
    gosub getsamplebyte
    b9 = b7*3
    b11 = b11 & b9
    b11 = b11/b7
endgetsample:
