Hi all, wondering if anyone has tried installing VSM on Windows Server 2008 R2? I am running the latest version (7.10 with all the parts updates). It installs perfectly fine under Server 2008 R2, problem is when I go to install the license key. It installs the key under the license manager, but when I go to open VSM it opens in demo mode, prompting me to register the software, as if it doesn't recognize the installed license. The license is valid because I am also running it on Windows 10 with no problems.
BTW, the reason I am installing on Server 2008 is because I need to run it as a RemoteApp on a Chromebook, so a terminal server is required to do this.
I have already tried running the install as admin and in compatibility mode for server 2008 to no avail. I suspect the registry location for the license info is different on Server 2008 but not sure, since I don't know where to look.
Any suggestions would be appreciated. Many thanks.
