E have to send data from Pic-A to Pic-B and then from Pic-B to the PC terminal. when i look at the output of Pic-A withe the terminal it is fine but when i look at the output of Pic-B it is not OK Peace help me to fix this code it is a urgent matter.
Pic-A code:
'----------------- Disply to PC and Pic-B ------------------------
PC_Disply:
hsersetup B9600_8,%10 'For pc conection
sertxd (cr,lf,"MSG in MEMMORY= ")
high B.6 'Turn Radio on
pause 2000 'Wate 2seconds for radio to stabalise
hserout 0,(cr,lf)
for w2=1 to Last_Ram
'on startup (symbol Char1=b16)
readi2c w2,(Char1)
pause 10
sertxd (Char1)
pause 10
hserout 0,(Char1)
next w2
hserout 0,(cr,lf)
hsersetup B9600_8,%00
sertxd (cr,lf)
Low B.6 'Turn Radio off
The output:
Pic-B code:
hserin [10000],0,65
b1 = hserptr - 1 'the hserptr holds the number of bytes rcved
sertxd (cr,lf,#b1,cr,lf)
if b1=52 then
for b2 = 0 to b1 'iterate through the data
get b2,b3
sertxd (#b3) ' re-transmit the item ro PC
next b2
end if
goto main ; loop
The output:
Pic-A code:
PC_Disply:
hserout 0,(cr,lf)
readi2c w2,(Char1)
pause 10
sertxd (Char1)
pause 10
hserout 0,(Char1)
next w2
hserout 0,(cr,lf)
sertxd (cr,lf)
The output:
Pic-B code:
hserin [10000],0,65
if b1=52 then
get b2,b3
next b2
end if
goto main ; loop
The output:
