davefish55
I have searched around to see if this has been handled and can't seem to find anything. I have an existing axe project that uses 4 magnetic reed switches on 4 axe inputs to determine which of 16 different lighting behaviors occur on a set of 5 LEDs. This is an 18X chip and inputs are through a ULN2803A. I would like to replace the current behavior with an 08M driving the 18X power on and off, while changing the open/closed state with 4 of the 08M pins. I am wondering -- can I drive the power (or ground leg) directly off an 08M pin, or should I use a relay or transistor? Should I use something like a BC548 as the "switch" for the 18X (driven by the 08M)? And my second question -- can I just treat the 08M outputs as being similar to the 5V currently being put on the 18X inputs through the 2803? Or do I need to take that out of the circuit. I am afraid my questions demonstrate the limits of doing projects by looking at existing circuits and code and trying to make something new. I'm not that bad on the code side, but very weak with the electricity. Thanks for any help.
