There is much more to the PICAXE firmware than just a bootloader. Furthermore, it is the small premium added to the cost of the blank PIC chip that provides the income for Revolution Education; the remaining software is free. Therefore you are not going to get your hands on the firmware. If your requirements are sufficiently large then it might be worthwhile contacting Revolution Education and seeing if you can negotiate a deal to program up your required number of PICS, but I suspect that this number would be fairly considerable before they would undertake such a task; its not going to happen for a handful.
One possible compromise solution is to step back a couple of years in PICAXE development when Programming Editor would convert the program into assembler for loading directly into a blank PIC using their PIC Programmer (
http://www.picaxestore.com/index.php/en_gb/bas800.html ). All this is still available. The only problem is that the software stopped development at the PICAXE28A - the PIC16F872. This chip does, however, appear to be available in the 28 pin SSOP package that you require (
http://uk.rs-online.com/web/p/microcontrollers/8248746/ ) You would have to arrange your own connections between the BAS800 and your chip, but it seems to be quite feasible. The only restriction that I can think of is that the range of operation on the old PICAXE28A is obviously more limited than the latest PIC version - e.g. PORTA = analogue input; PORTB = output; PORTC = digital input.
Have a look at Programming Editor 5.5.6 - the last version of the software that will support conversion to assembler and see if it would work for you. PICAXE Manual 2 still lists the 28A next to all the BASIC commands that are available.
