Picaxe math restriction
rbright
Pixaxe will only allow integer calculation and then only with values less than 65535.
I'm trying to process some negative temperature values from a DS18B20 and I need to divide by a fraction as follows:
I have 16 bit word W1 which contains FF5E. I want to subtract that from FFFF then divide the result by 0.0625.
Any ideas
MPep
Do a forum search.
I found the following
It's will return anything between -55 to 125ºc
The positive values will be returned directly such as b1 = 25
The negative values will be everything bigger than 127. In this case, you'll have to substract 128 from this value.
Having that, you can have something like.
b1 = 140
So, b1 = 140 - 128
Then b1 = 12
That means you have -12ºc
Okay, this is for 8bits only but you get the idea.:D
2's complement is used here.
rbright
Now Working - see other post today
Thanks for the hints to use 2's Compliment - of course that is what the DS18B20 was expecting to have to process it's negative values. I've just posted on another thread the resulting code as a bit of a tutorial for others but with lots of comments
