Andrei IRL
Hi everyone.
I have a strange failure of the PICAXE M08 chips and i can not figure it out.
The worst part about it after the chip has failed it send one of the PINS high which turns on a relay killing everything connected to it.
Is it possible to have a Fail Safe to prevent that?
I have used same curcuit for many years and it worked perfect, the only difference this time is the use of PNP proximity sensor.
PNP Proximity sensor sends out 12V signal which is brought down to 3.8V by the use of Voltage devider and as a precaution i also have a 4.7v Zener.
So the only thing i could think off is that Proximity sensor kills the chip.
I have tested this curcuit over many of hours running off a 12V battery and it works perfect. However, this project is for a motorcycle.
Ignore the power supply in the diagram as im using LM7805 with Two caps at either sise plus 100nF right at the Chip.
Im thinking may be i would be better off with a NPN Proximity sensor then i'll be reading LOW signal as my trigger and no fear of excessive voltage killing the Chip.
I would appreciate any ideas ye might have.
P.S. I did check all the signals with a scope to make sure the proximity sensor is not creating any back EMF and it all looks good (bench tested only not while on a motorcycle)..
Thanks very much.
Thanks very much.
