Dear All,
I have mounted the AXE 090 Board.
BUG: The voltages ooff my battery is 9V or so. The Voltage on the chips + pins, stay around 8.5 , far away from the admitted 5V.
My 7805CT voltage regulator is soldered as on pictures, metallic part against the board, viewing name on top.
Placed as I can read the regulator name, pins bottom: If I well look , the POWER+ input connector is connected on the right pin of the 7805 marked DC; the middle one is to ground and the left one (marked +) goes to chips.
I think this voltage regulator is wrongly cabled. Pins 1 and 3 (left/right) should be inverted as the voltage may in on the left pins and out on the right one.
Can you please confirm that the 7805 has to be flipped top/bottom to reverse it?
Thx for help,
Sincerelly.
Hervé
Thx for help,
Sincerelly.
Hervé
