G'day from Darwin,
I have a Kenwood TS-50 Ham transceiver with matching AT-50 automatic antenna tuner. The radio is a bit flakey and beyond economic repair. A friend has arranged another HF radio but it doesn't put out any signals regarding what band it is transmitting on.
The first solution is to buy an ATU that only needs RF input, and it can work out the frequency and best match for the antenna. An SGC-230 costs about $700.
The smarter, cheaper way is to get a Picaxe to do the talking to the ATU. I got this (somewhat cryptic) info from DK.mods.
BTW the ATU is in another cabin, near the aft end of the boat where the antenna wire exits to the back-stay.
Communication method: Serial interface
Tranfer rate: 4800 bps
Synchronization: Start-stop (Asynchronous)
Parity: None
Signal format: TTL level (!)
2: TT (TS50<--AT50)TTL!
3: TS (TS50-->AT50)TTL!
Firstly the TS50 and the At-50 talk to each other on power-up.
1. at Power-on:
+------------------+ ++1 ++3++6
TT--+ +---------------------->
| 1.45 sec---+ | | |
+--+ ++2 +-+4,5
TS- + +--------------------------------------->
| |<- 600ms->|
0 + 90ms resume time t
Sorry, this timimg diagram is not showing the spaces correctly, so its a bit of a mess.
Signal:
1 3 6
TT: ;;;;;0C;___0D01;__________0F11;
2 4 5
TS: ________0C;_____0D01;0F11;____
1: Power on comm.
2: Power on answer
3: Auto on request
4: Auto resume finished
5: ok at50
6: ok answer ts50
When the TS-50 is tuned from one band to another, it tells the AT-50 which band. The AT-50 stores the frequency and antenna settings in memory.
The info looks like this:
2. DOWN-UP-Communication
TT: 0E02;__________0F11;__ - UP from 1.8 to 3.5
TS: _____0E02;0F11;_______
same:
0E04;0E04;0F11;0F11; UP 3.5 --> 7
0E05;0E05;0F11;0F11; UP 7 --> 10
0E06;0E06;0F11;0F11; UP 10 --> 14
0E07;0E07;0F11;0F11; UP 14 --> 18
0E08;0E08;0F11;0F11; UP 18 --> 21
0E09;0E09;0F11;0F11; UP 21 --> 24.5
0E0B;0E0B;0F11;0F11; UP 24.5--> 28
0E0C;0E0C;0F11;0F11; UP 28 --> 29
0E01;0E01;0F11;0F11; UP 29 --> 1.8
DOWNs
TUNE: 0D03;0D03;0F41;0F41;
AUTO OFF (THRU): 0D00;0D00;
AUTO ON: 0D01;0D01;
tune error: 0d03;0d03;0F83;0F83;
It seems to me that by having a rotary 12-position switch I should be able to tell the 'axe what band I want, and whether it is up or down. I then press the Tune button for the ATU to do its stuff.
Not having done any serial work with the 'axe I am at a bit of a loss on how the handshaking will work. In the first example,
The 'axe has to hear the 0e02, respond with 0e02;0f11, then wait for the 0f11. How is this done?
Sorry about the long post. I just hope some of you gurus out there can point me in the right direction. I really don't want to spend anoher $700, this trip has cost me plenty already!
paulr
on the way to Indonesia in 2 weeks.
Parity: None
1. at Power-on:
| 1.45 sec---+ | | |
+--+ ++2 +-+4,5
| |<- 600ms->|
Signal:
1 3 6
2 4 5
1: Power on comm.
2: Power on answer
3: Auto on request
5: ok at50
6: ok answer ts50
same:
DOWNs
AUTO ON: 0D01;0D01;
paulr
