J jimuck New Member Jun 25, 2010 #1 Hi, Was wondering if any of you guys knew how to solder on the header pins on the lcd; the way the instructions seem to tell me is to only solder one side of the main pcb?
C centrex Senior Member Jun 26, 2010 #2 I think you would find that the lcd has plated through holes so it does not matter which side you solder the connection will be made. regards
W westaust55 Moderator Jun 26, 2010 #3 @jimuck, welcome to the PICAXE fourm. centrex is correct. The holes are plated through so there is only a need to solder on one side
