While reading through the manuals and getting more general information with respect to each chip, I noticed that each pin can sink or source 20mA. After doing some digging on other current sources, mainly for driving multiple LEDs, a thought came to me and I was hoping to get some clarity on this.
Can any picaxe chip be used as a current source? My thinking is that if you simply turn all the pins high and have them all come together through some array, say through a Darlington Array, can you combine them to get the 200mA max provided by the chip as a current source?
If a 08M2, as an example was used, could you turn the pins high and feed them into a 6 input Darlington Array, tie the 6 outputs together and have (in this case) 120mA usable as a constant current? There exist many other ways to do this but just writing up some simple code and using a darlington array seems like a much easier and fool-proof method. So, is this possible?
