I have used the following code successfully for the PICAXE-28X1 chip. How do I modify this code to work for the PICAXE-28X2 as I get a syntax error at 'PINS=Outbyte'?
Better to also configure the Port B pins for output (on the 28X2 they probably default to input pins): let dirsB = %11111111.
When in doubt about this conversions (or to avoid doing it manually), you should use the "X2 Conversion" wizard. You'll find it in the "Picaxe" menu on the Programming Editor.
#picaxe 28X1
symbol countum=b0
symbol Outbyte=b1
lookup countum,($BE,$82,$DC,$D6,$E2,$76,$7E,$92,$FE,$F2), Outbyte
PINS=Outbyte
#picaxe 28x2
' Converted by X2 Conversion Wizard Version 2.0.1 (2010r3)
let adcsetup = 0
symbol countum=b0
symbol Outbyte=b1
pinsB=Outbyte
BTW, welcome to the Picaxe forum. And don't be affraid to post your questions on the Active Forum section, rather then the Sandbox...
