paul george
Will a picaxe 28X2 work on picaxe 28 starter board??
That depends on the complexity of your project.do you think weather a PICAXE 40X2 will be better for such humanoid, i hav already made a robot.
Your question is unclear. Are you in need of the PICAXE Pinouts and Download Circuit?But am not getting any schematics for picaxe 40X2 circuit connection.
The 40X2 and 28X2 PICAXE chips both have the same set of commands, same memory. The primary difference is that the 40 pin chips have an addiitonal 11 IO pins (as a complete Port D and some extra PortA pins).do you think weather a PICAXE 40X2 will be better for such humanoid, i hav already made a robot.
I want to know about the 40X2 download circuit..Your question is unclear. Are you in need of the PICAXE Pinouts and Download Circuit?
All of the PICAXE chips from 8 pin to 40 pin variants use the same download circuit.I want to know about the 40X2 download circuit..
The download circuit for the 40X2 is the same as the download circuit for the other PICAXEs.I want to know about the 40X2 download circuit..
