Hi people, I have a problem with the picaxe 28 pin project board.
I am attempting to control 24v dc relays via the darlington chip. This I have done
many times with 40X project board with external driver chips. However, When I connect
the board using a single 4.7v supply, all is well. I can talk to the 28X1 etc. As soon as I
common the 0V from the 24V relay supply with the 4.7V supply 0v I lose communication
with the chip and the voltage across the chip supply is reduced to 3.6V....... strange.
If I then connect the +24V to the V2 supply and change the jumper settings as per the manual the chip blows up due the voltage raising to +13 odd volts...... stranger.
So can anyone tell me where I am going wrong, possibly supply an absolutely definitive
diagram for this application PLEASE. In other applications using elays it has only been neccesary to common the 0 volts and off it goes!
Thank you all
Dave Black
Thank you all
Dave Black
