Any help would be gratefully received...
I have written a program and developed a circuit to adapt the entry in the PICAXE Manual 1 FAQ section regarding extending the number of output ports available. The circuit is built on a standard REV-ED PICAXE 20 PCB, and consists of 6 red/green leds (with associated resistors, of course) connected across adjacent ports. 4 are on port B (0/1, 2/3, 4/5, 6/7) and 2 are on port C (0/1, 2/3). The serial input will be on port c.7. All the leds light correctly; however, I require the leds to basically show the binary equivalent of the input where a green led is equivalent of logic 0 and a red led is equivalent to logic 1. I have tried the program in simulated mode outside of the PCB and it appears to work correctly in that when you enter a number in the simulator it is carried over to the program as you enter it. However, in order to test it downloaded onto the PCB, it appears that only the lowest significant bits register (0-9) when using SERRXD command. For example, if you enter 45 in the terminal window, only the '5' registers. I can't get anything sensible from the assembly at present; I have tried using word variables without luck. The only way I managed to get something sensible out of it was by adding the 'let b1 = b3 - 33' command and using ASCII characters (from !(33)to '(96)) in the terminal screen. When operated this way I can get all 6 leds to indicate exactly as required. However, I am not keen to use this method when the assembly is completed as the driver circuit will consist of a 40X2, and it was easier to just have this output a number to send to this 20X2 and that should work according to the manual. Putting the '#' in front of the input variable in an attempt to get a raw input doesn't seem to have any effect at all. Help...
'This program is to control the LOP indicators on the new Smithfield Panel
'b1 = 0 - 15 for Points 6, 7, 8, 9 only
'b1 = 16 - 31 adding Point 10 only
'b1 = 32 - 63 adding point 24 only
'Refer to ASCII table - codes begin at 33 (!) and end at 96 (`) - for characters to send when using SERRXD
#picaxe 20X2
let dirsb = %11111111
let dirsc = %00001111
let pinsc = 5
let pinsb = 85
let b2 = 0
disconnect 'this is required for the serrxd command
serrxd b1 'use this command to test module
'serin c.7,N4800,b3 'use this command when running normally
pause 10
'let b1 = b3 - 33
if b1 = b2 then goto main
if b1 >= 64 then goto main
if b1 >= 0 and b1 <= 15 then let pinsc = 10 : let b2 = b1 : goto low_four : endif
if b1 >= 16 and b1 <= 31 then let pinsc = 9 : let b2 = b1 : let b1 = b1 - 16 : goto low_four : endif
if b1 >= 32 and b1 <= 47 then let pinsc = 6 : let b2 = b1 : let b1 = b1 - 32 : goto low_four : endif
if b1 >= 48 and b1 <= 63 then let pinsc = 5 : let b2 = b1 : let b1 = b1 - 48 : goto low_four : endif
if b1 = 99 then test_over
low_four:
if b1 = 15 then let pinsb = 170 : endif
if b1 = 14 then let pinsb = 169 : endif
if b1 = 13 then let pinsb = 166 : endif
if b1 = 12 then let pinsb = 165 : endif
if b1 = 11 then let pinsb = 154 : endif
if b1 = 10 then let pinsb = 153 : endif
if b1 = 9 then let pinsb = 150 : endif
if b1 = 8 then let pinsb = 149 : endif
if b1 = 7 then let pinsb = 106 : endif
if b1 = 6 then let pinsb = 105 : endif
if b1 = 5 then let pinsb = 102: endif
if b1 = 4 then let pinsb = 101: endif
if b1 = 3 then let pinsb = 90 : endif
if b1 = 2 then let pinsb = 89 : endif
if b1 = 1 then let pinsb = 86 : endif
if b1 = 0 then let pinsb = 85 : endif
sertxd (#b1)
test_over: 'this is only needed when using serrxd command
pause 100
reconnect
pause 100
let pinsb = 85
let pinsc = 5
pause 100
stop
