Picaxe 20M Syntax
James Barrie
I would appreciate some guidance. Being a rank novice at programming but having read the manuals I am unsure of the proper syntax in identifying input pins and output pins. My project is a simple logic requirement to detect an input when it goes low and asigning specific output pins as low or high.
Thanks in advance
Barrie
Welcome to the PICAXE forum.
The general syntax is to use the pin number ( 0, 1 etc ) when using a command to control or access a pin ( HIGH, LOW, PULSIN, COUNT ) and to use the pin variable ( pin0, pin1 etc ) when wanting to know what that pin's input level is or to set it ...
High 1
Low 1
Count 1, 1000, w0
b0 = pin1
pin1 = b0
If pin1 = 0 Then
Do While pin1 = 1
James Barrie
Thanks for the welcome and guidance
How do you differentiate between an input pin number, output pin number and the physical component pin number
High 1
Low 1
Count 1, 1000, w0
b0 = pin1
pin1 = b0
If pin1 = 0 Then
Do While pin1 = 1
Input pin and output pin have the same naming convention '1' or 'pin1' etc, whether input pin or output pin depends on the context of the command used - SERIN 1 is an input command so references an input pin, SEROUT 1 is an output command so references an output pin. For use of "pin1", again that's context "pin1 = b0" sets an output pn, "= pin1" reads an input pin, likewise with "If pin1 = 1 Then".
"Pin" is the name given to a PICAXE connection in or out, their location on each chip is defined in PICAXE Manual 1. To differentiate between the leg number of the chip ( also called "pin" by the industry ) we have generally adopted the terminology "leg" for referring to a physical chip leg, "pin" when referring to a software pin.
Some people disagree with this "leg" and "pin" terminology but IMO is a handy and convenient shortform; "output pin 1 is Leg 21 of a 20M" against "software output pin 1 is physical chip pin 21 of a 20M", and the temptation to shorten the later to "pin 1 is on pin 21", which is quite confusing.
@Barrie,
Might I suggest that in future you post in the ACTIVE forum area at the top of the main PICAXE forum screen. You will get far more folks read your question and resopond i the Active area.
This is the Sandbox where folks usually try out ideas, etc, and is not visited by nearly as many members.
James Barrie
Please review my first attempt
Hippy
Would you take a look at my first steps at logic for a left right up down control of two motors providing azimuth and elevation
Thanks
Barrie
input1=b1 'input pins are b1,b2,b3,b4
input2=b2
input3=b3
input4=b4
let outpins=pins 'ouput pins are pin 1.2.3.4.5.6,7,
outpin1=pin1
outpin2=pin2
outpin3=pin3
outpin4=pin4
outpin5=pin5
outpin6=pin6
outpin7=pin7
if b1 is off then endif 'call for right turn
Let pins = %00011000 'az motor turns right
if b1 is on then endif 'call for stop
Let pins = %00000000
if b2 is off then endif 'call for left turn
Let pins = %00010100 'az motor turns lext
if b2 is on then endif 'call for stop
if b3 is off then endif 'call for up
Let pins = %11000000 'el motor turns up
if b3 is on then endif 'call for stop
if b4 is off then endif 'call for down
Let pins = %10100000 'el motor turns down
if b4 is on then endif 'call for stop
Have you tried running it through the Programming Editor Simulator ?
You have a few problems -
I'd guess you want it the other way round; "b0=input1" to read input1 into b1.
outpin1=pin1
I'm less sure of what you are trying to do there, but that will set the outputs to values of input pins.
Won't actually achieve anything. The IF-ENDIF should wrap around one or more statements to execute when the condition is met.
The best thing to do when starting is to start simple. Get a single output working from a single input, then move on to things more complicated. For example, with a button to +V to Input Pin 1 and a pull-down to 0V, a LED+R between Output Pin 2 and 0V you can light the LED when the button is pushed with any of the following -
Do
  If pin1 = 1 Then
    High 2
  Else
    Low 2
  End If
Loop
Do
  If pin1 = 1 Then
    pin2 = 1
  Else
    pin2 = 0
  End If
Loop
Do
  pin2 = pin1
Loop
Don’t forget the “LOOP” command at the end of the first two examples hippy has given. Needed as shown in the third example
James Barrie
Good Day Hippy
Thanks for your guidance and suggestion to start simple. Interestingly the motto for our town is " Make Haste Slowly"
I have been able to get the logic sequences I need to control LEDs I have on the oututs. Now to bring all the hardware together
Thanks again
Barrie
Excellent progress and good to hear you're advancing, so good luck with the hardware.
