I try a 18X Picaxe with 2x20 lcd display .
LCD module DATA VISION DV-20 208
http://www.pollin.de/shop/dt/MDg0OTc4OTk-/Bauelemente/Aktiv/Displays/LCD_Modul_DATAVISION_DV_20208.html
Wired is all in how PicAxe Guide 3 interface (p. 38) and I try the local routine to get started (in 4 bit mode). The levels are also on the correct pins, the LCD so far I can only adjust the contrast.
Sticking point is probably the controller of the KS-0066 is supposed to be compatible HDD44780 ...
Has someone already brought this on PicAxe controller to work??
Thank you
Thank you
