kalyan chilukuri
hi i am using a picaxe 18x. by using the ultrasonic sensors i get the distance say variable range. i also have a atmega8535 which i have hooked up to an LCD, SPEAKER etc. i was wondering if it was possible to send the variable range from the picaxe to the Atmega. at this stage i want to use a wire to connect the two then at a later stage i wish to communicate wirelessly but since it is for any electronics project i have to go step by step so if you have any info on sending range from picaxe 18x to Atmega through wiring it would be helpful.
any advice would be appreciated.
