Somehow I thought this chip was to be a replacement for the 18A and 18X chips, yet none of my 18A/18X projects work!!!
I'm struggling to find anything in one place that would describe how to change your old programs to work either.
* Seems like port B needs to be told its output before anything leaves the chip
* bit inputs seem unreliable, ADC ok
* "standard" LCD program/subroutines from Hippy which worked one the 18A and 18X don't
You'd think there was a directive to make the new chip run like the older ones its meant to replace, or a guide if you had to make the changes manually.
So far, the only thing I find these chips share is that they all have 18pins!
I held out so much hope for this chip's process power, that I'm hoping I can be set straight on how to make it work.
Sorry for my post being such a downer...
PS:Using program editor 5.3.1
