laserhawk64
Hello, all! I'm new here, so please be gentle.
I had an idea, the other day, for something like this: http://www.linusakesson.net/scene/bitbanger/index.php
I want to use a PICAXE 08M2. The idea is to run it at 25.175MHz using the input-only lead C.3, and have it output random 8bit strings from three IO leads (C.1, C.2, C.4) which would be converted to raw VGA via a trio of 74xx595 ICs paired with R-2R ladders. I can scan the (hand-drawn) schematic and post it, but I will warn you that my chickenscratch is not the most readable -- and this particular schematic is not my neatest!
My primary question relates to the clock issue: is it possible to drive the 08M2 from an external clock at all? If so, would non-integer values be supported?
My secondary question is: OK, if I can do the clock input, how would I implement that in software? I can probably figure out the rest of it (I program occasionally) but this clock issue has me just boggled.
