In the past ,with your help I was able to build a Pelco D protocall decoder using a picaxe 18x which is at this link:
http://www.picaxeforum.co.uk/showthread.php?t=9773&highlight=pelco
I am wondering if I could get any help building a controller that would send out Pelco D protocall when switches are pressed.
I am just getting back into using the Picaxe so I may be slow in understanding but I would appreciate any help you can give.
In my last thread Hippy wrote: "That should be pretty straight forward. Just put what you need to send in a few byte variables, add those up to create a valid checksum and send those variables using SEROUT at the right baud rate.
If you need further help I can come back to this if you want ( bit busy at the present time )."
Unfortunately the only parts I really understand are are the SEROUT and baud rates....Ill try and start looking at some code as a starting place. I am hopeing someone can help me get from there to where I want to be. Thanks for any help/advice3. T
