PE6 freezing
Chris Kelly
Active member
Hi guys
Running PE6 on Windows 10. I'm working on some code which works fine, but when I try to alter one of the sections it freezes during simulation.
Here is the code
#picaxe 20m2
#no_data
symbol StepLen    = b0
symbol Pulses    = b1
symbol StepLenADC    = b2
symbol PulsesADC    = b3
symbol StepLenChk = b4
symbol PulsesChk  = b5
symbol NewTotal     = b6
symbol Total     = b7
symbol Remainder    = b8
symbol StepPosn     = b9
symbol DrumHit    = b10
bptr    = 32
gosub CheckStepLenADC
gosub CheckPulsesADC
if    StepPosn < StepLen then
    NewTotal = Total + Pulses
    if     NewTotal >= StepLen then
        Remainder = NewTotal - StepLen
        DrumHit = 1
        @bptr = DrumHit
        NewTotal = Remainder
        Remainder = 0
    else    DrumHit = 0
        @bptr = Drumhit
    end if
    Total = NewTotal
    inc bptr
    inc StepPosn
    DrumHit = 0
end if
readadc C.1, b2
if StepLenADC != StepLenChk then
end if
readadc C.2, b3
if PulsesADC != PulsesChk then
end if
if    StepPosn = StepLen then
    Total     = 0
    NewTotal     = 0
    Remainder     = 0
    StepPosn    = 0
    bptr = 32
end if
CheckStepLenADC:
tablecopy 32,47
readadc C.1,b2
Select StepLenADC
    Case <16
    StepLen = 1
    Case 16 to 31
    StepLen = 2
    Case 32 to 47
    StepLen = 3
    Case 48 to 63
    StepLen = 4
    Case 64 to 79
    StepLen = 5
    Case 80 to 95
    StepLen = 6
    Case 96 to 111
    StepLen = 7
    Case 112 to 127
    StepLen = 8
    Case 128 to 143
    StepLen = 9
    Case 144 to 159
    StepLen = 10
    Case 160 to 175
    StepLen = 11
    Case 176 to 191
    StepLen = 12
    Case 192 to 207
    StepLen = 13
    Case 208 to 223
    StepLen = 14
    Case 224 to 239
    StepLen = 15
    Case > 240
    StepLen = 16
end select
StepLenChk = StepLenADC
CheckPulsesADC:
tablecopy 32,47
readadc C.2,b3
Select PulsesADC
    Case <16
    Pulses = 1
    Case 16 to 31
    Pulses = 2
    Case 32 to 47
    Pulses = 3
    Case 48 to 63
    Pulses = 4
    Case 64 to 79
    Pulses = 5
    Case 80 to 95
    Pulses = 6
    Case 96 to 111
    Pulses = 7
    Case 112 to 127
    Pulses = 8
    Case 128 to 143
    Pulses = 9
    Case 144 to 159
    Pulses = 10
    Case 160 to 175
    Pulses = 11
    Case 176 to 191
    Pulses = 12
    Case 192 to 207
    Pulses = 13
    Case 208 to 223
    Pulses = 14
    Case 224 to 239
    Pulses = 15
    Case > 240
    Pulses = 16
end select
PulsesChk = PulsesADC
I want to change the If....end If statement shown below to a Do While ….. Loop statement instead. This change alone causes the freeze:
        DrumHit = 1
        @bptr = DrumHit
        Remainder = 0
    else    DrumHit = 0
        @bptr = Drumhit
    end if
    Total = NewTotal
    inc bptr
    inc StepPosn
    DrumHit = 0
end if
So if I replace this snippet of code with
do while StepPosn < StepLen
        DrumHit = 1
        @bptr = DrumHit
        Remainder = 0
    else    DrumHit = 0
        @bptr = Drumhit
    end if
    Total = NewTotal
    inc bptr
    inc StepPosn
    DrumHit = 0
this change causes the freeze during simulation.
Is my change inherently bad, or is the rest of the code unwieldy and causing the freeze?
I always make sure there are no other programs running in the background.
Hope you can help?
Cheers
Chris
Aries
Unwieldy code should not be the problem. The likely explanation is that the do...while is never terminating. Add some sertxd statements within the loop and see what happens. Alternatively, step through the simulation, watching what happens and where it goes.
Buzby
Hi Chris,
As Aries says, it's not the code that freezes PE6, it's more likely due to your simulation speed setting.
On my Win 10 laptop, if I set the slider to 100mS or less, PE6 goes very unresponsive.
Sometimes the code is still running, and the variables in the Code Explorer pane update nice and quickly, even though the main window has 'frozen'.
But usually I just get the 'Not responding' message in the title bar, and the little blue 'waiting' wheel. I then need to use Task Man to kill PE6.
This behaviour has been discussed in the forum, but no solution seems forthcoming, so I don't run simulations faster than 100mS.
It is a real problem, as PE5 ran faster, but had a limit at 20mS, that's why I asked for a 'run with no GUI' in the PE6 wishlist.
Cheers,
Buzby
