This question is for the Technical staff, but I'm open to any advice / suggestions:
I have a laptop running Windows 8.1 and up until yesterday, I only had PE 5.5.5 loaded.
Wanting to try the new PE6 Beta, I downloaded and installed it - without remembering to remove the 5.5.5. version..... Yes, I know, probably not a smart move on my part...
Can I have a PE6 and a PE5 version installed at the same time? Is this acceptable? Will they get along with each other?
The reason I ask is that I was playing around with the 6.0.6.2. BETA and a 28X1 chip (Firmware v A.6), on the AXE091 Development board, and had this code loaded:
The only thing on the development board, aside from the 28X1 chip, is a jumper wire from the 28X1's pin 14 (C.3) to the L1 pin (Green LED).
I uploaded the code and received a successful upload confirmation, and expected the green LED to blink on for a second then off for a second per the code, but nothing happened - The LED remained off.
After about 30 minutes of getting nowhere, I shutdown PE6 Beta and started up PE5 and loaded the identical code. After a successful upload message, the LED began blinking as expected.
I tried this at least three times and each time the same result: Always got an OK message after the upload, but the LED only blinks when the code is uploaded with V5.5.5.
To see if the issue was isolated to Port C, I moved the jumper wire from pin 14 (C.3) to pin 24 (B.3) and changed the code to:
Loading that code with either V5 or V6 results in the LED blinking as expected, so it seems to be a Port C issue somehow...
I was going to remove both PE versions and start from scratch - only loading the PE6 BETA version, but I thought I'd ask here before doing anything further.
The other thing I noticed, is in the "Programs and Features" list for Win 8.1., there is only one entry for "PICAXE PROGRAM EDITOR" with yesterday's date. So, I'm assuming here that if I uninstall that, it will uninstall V6, but not the V5,
Any thoughts as to why the code doesn't work with PE6?
And lastly, if I do indeed have to remove both and start over, how can I ensure that all traces of V5 are gone? Is just deleting the directories sufficient?
Thanks for your time and effort,
Regards, John.
#picaxe 28x1
dirsc = %00001000
pinsc = %00001000
wait 1
pinsc = %00000000
wait 1
#picaxe 28x1
pins = %00001000
wait 1
pins = %00000000
wait 1
Regards, John.
