Talk about a mind block! I have done this before, I think...
I am trying to transfer a value from an 20m2 to a 08m2 that will be used as a variable in a servo command (servo c.2, b1)
What commands do I use?
Thanks!
serout and serin, possibly with a timeout on serin if hardwired. Depending on what you are doing, handshaking might be required. It is possible to handshake on the same line you are using for the serial connection.
When controlling servos, if using SERVO and SERVOPOS commands, you may want to use HSERIN rather than SERIN to prevent any blocking from disrupting the servo, and any timeouts of SERIN causing you to miss data.
That HSERIN would also be recommended if using a bit-banged servo timing loop. Untested ...
HSerSetup ...
Servo SERVO_PIN, 150
Do
w0 = $FFFF
HSerIn w0
If b1 = 0 Then
ServoPos SERVO_PIN, b0
End If
Pause 10
Loop
