Dear All,
Thanks for all the help with my last question, re: programming picaxe problems. I have now sorted that out.
I have a new requirement for my project.
2 picaxe chips and I want to pass a number between the two chips. The number would range between 1 and 9. I want to use one picaxe for my sensors and the other picaxe to control my motors via a L239D chip. I want the sensor chip (depending on sensor) to pass the number back so the motors can respond accordingly. This only needs onw way comm from sensors to motor board.
Not asking for the solution, but wouldnt mind a few pointers. Even if it is what part of the manual to read.
I am assuming based on what I have read that standard protocol would be to have motor control and sensor control running from two different chips. I will be then driving the motors in tank track config.
This is really a side question but thought I would pop it in anyways. Assuming I have the right chip written down (but I am using the right one) L239D how do I connect a high voltage to the chip? Is this done by attaching my + < voltage to pin 8, but where do I connect the negative from the second power source? I want to use 12V for the motors.
As Usual
(oo) NoIdea (oo)
As Usual
(oo) NoIdea (oo)
