Bill.b
Hi I found that some commands effected the servo command, in my case it was the IR commands. The following
is a portion of code for a free roaming bot to control the panning of a SFR005 ultrasonic scanner.
Regards Bill
'this is a part of a free roaming bot program (bot120 picaxe 20x2). the following section controls the pan of
'of a SRF005 ultrasonic scanner.
'the servo uses pulse out command in place of the usual servo commands. this is
'because this bot also used IR commands for control. when the servo commands where used, an IR command would
'cause the servo move to the extreem left. the pulse out command rectified this problem.
setfreq = m8
Symbol trig = C.4 'front range sensor ADC input
Symbol SERVO1 = b.0
Symbol leftPath = w13 'Obstruction value on left side
Symbol rightPath = w14 'Obstruction value on right side
Symbol range = w12 'output from SRF005
Symbol SERVOLeft = 150
Symbol SERVORight = 350
Symbol SERVOCent = 260
DistanceMessure:
pulsout trig,2 ' produces about 20uS pulse (must be minimum of 10uS)
pulsin trig,1,range ' measures the range in 10uS steps
pause 10 ' SRF005 mandatory 10mS recharge period after ranging completes
let range = range * 10 /58/2 ' multiply by 10 then divide by 58 then by 2 (8meg)
If range > 20 then 'all clear
let pinsb =%00001010 'stop bot
pause 200
let pinsb =%10100000 'Reverse bot
for b50 = 1 to 10 'pulse output to servo 1
pulsout SERVO1,SERVOLeft ' Turn head to look left
pause 20
next b50 ' Turn head to look left
Pause 200 ' Wait for servo to move
pulsin trig,1,leftPath ' measures the range in 10uS steps
pause 10 ' SRF04 mandatory 10mS recharge period after ranging completes
let leftPath = leftPath * 10 /58/2 ' multiply by 10 then divide by 62
for b50 = 1 to 20 'pulse output to servo 1
pulsout SERVO1,SERVORight ' Turn head to look right
pause 20
next b50
pulsin trig,1,rightPath ' measures the range in 10uS steps
let rightPath = rightPath * 10 /58/2 ' multiply by 10 then divide by 62
pulsout SERVO1,SERVOCent ' Turn head to look forward
pause 20
next b50
If leftPath < rightPath Then
gosub turnleft ' Turn in the direction that has more room
Else
gosub turnright
Endif
