danners430
Hey guys,
A quick question regarding overclocking. I know that overclocking a chip to a higher frequency changes the "actual" speed of the baud rate set when you send a serial command. However, i want to send serial commands to another picaxe chip. if I overclock both chips to the same frequency, some quick logic would say that the "real life" baud rate would still be the same across both chips?
Just means I can use a common baud rate as long as I also use a common frequency!
cheers
cheers
