Symbol ADVal = W0
Symbol TC_100 = W0 ' ADVal not needed when TC_100 is calculated
Symbol ADValHi8 = B2
Symbol ADValLow2 = B3
Symbol N = B4
Symbol Diff = B5
Symbol Whole = B6
Symbol Fract = B7
Symbol SignFlag = B4 ' N is not need when this is used
Symbol Diga = B5 ' Diff not needed when this is used
symbol loop_dump = w8
symbol math_dump = w9
symbol math_dump2 = w10
symbol temp = w11
symbol digit_1 = b12
symbol digit_2 = b13
symbol digit_1_buffer = b14
symbol digit_2_buffer = b15
' EEPROM locations 0 - 15 not used
EEPROM 16, (254, 236, 220, 206, 194, 183, 173, 164)
EEPROM 24, (157, 149, 143, 137, 131, 126, 122, 117)
EEPROM 32, (113, 110, 106, 103, 100, 97, 94, 92)
EEPROM 40, (89, 87, 85, 83, 81, 79, 77, 76)
EEPROM 48, (74, 73, 71, 70, 69, 67, 66, 65)
EEPROM 56, (64, 63, 62, 61, 60, 59, 58, 57)
EEPROM 64, (57, 56, 55, 54, 54, 53, 52, 52)
EEPROM 72, (51, 51, 50, 49, 49, 48, 48, 47)
EEPROM 80, (47, 46, 46, 46, 45, 45, 44, 44)
EEPROM 88, (44, 43, 43, 43, 42, 42, 42, 41)
EEPROM 96, (41, 41, 41, 40, 40, 40, 40, 39)
EEPROM 104, (39, 39, 39, 39, 38, 38, 38, 38)
EEPROM 112, (38, 38, 37, 37, 37, 37, 37, 37)
EEPROM 120, (37, 36, 36, 36, 36, 36, 36, 36)
EEPROM 128, (36, 36, 36, 36, 36, 35, 35, 35)
EEPROM 136, (35, 35, 35, 35, 35, 35, 35, 35)
EEPROM 144, (35, 35, 35, 35, 35, 35, 35, 35)
EEPROM 152, (35, 35, 35, 35, 35, 35, 35, 35)
EEPROM 160, (36, 36, 36, 36, 36, 36, 36, 36)
EEPROM 168, (36, 36, 36, 37, 37, 37, 37, 37)
EEPROM 176, (37, 37, 38, 38, 38, 38, 38, 39)
EEPROM 184, (39, 39, 39, 39, 40, 40, 40, 41)
EEPROM 192, (41, 41, 42, 42, 42, 43, 43, 43)
EEPROM 200, (44, 44, 45, 45, 46, 46, 47, 47)
EEPROM 208, (48, 48, 49, 50, 50, 51, 52, 53)
EEPROM 216, (53, 54, 55, 56, 57, 58, 59, 61)
EEPROM 224, (62, 63, 65, 66, 68, 70, 72, 74)
EEPROM 232, (76, 78, 81, 84, 87, 90, 94, 98)
EEPROM 240, (102, 107, 113, 119, 126, 135, 144, 156)
EEPROM 248, (170, 187, 208, 235)
put 0, %01111110
put 1, %00001100
put 2, %10110110
put 3, %10011110
put 4, %11001100
put 5, %11011010
put 6, %11111010
put 7, %00001110
put 8, %11111110
put 9, %11011110
low portc 3
Top:
GoSub MeasTemp
If TC_100 = $7fff Then OutofRange
GoSub DisplayTemp
OutofRange:
SerTxD ("Out of Range", 10, 13)
GoTo Top
MeasTemp:
ReadADC10 0, ADVal
pause 100
ADValHi8 = ADVal / 4 ' isolate the high 8 bits
ADValLow2 = ADVal & $03 ' low two bits
TC_100 = 10542 ' adjust this as required
If ADValHi8 < 16 Then TooHot
If ADValHi8 > 251 Then TooCold
For N = 0 to ADValHi8 ' continue to subtract
Read N, Diff
TC_100 = TC_100 - Diff
Next
' Now for the low two bits, a linear interpolation
N = N + 1
Read N, Diff
Diff = Diff / 4 * ADValLow2
MeasTemp_1:
Return
TooHot:
TooCold:
TC_100 = $7fff
GoTo MeasTemp_1
DisplayTemp:
SignFlag = Tc_100 / 256 / 128
If SignFlag = 0 Then Positive
TC_100 = TC_100 ^ $ffff + 1 ' twos comp
SerTxD ("-")
Positive:
Whole = TC_100 / 100
Fract = TC_100 % 100
SerTxD (#Whole, ".")
' be sure the fractional is two digits
Diga = Fract / 10
SerTxD (#Diga)
Diga = Fract % 10
SerTxD (#Diga, 10, 13)
' Check for Fan
if Whole>=20 then
high portc 3
elseif Whole<20 then
low portc 3
'Check for Alarm
if Whole>60 then
high portc 4
high portc 5
elseif Whole<=60 then
low portc 4
low portc 5
temp = Whole
SerTxd( "Temperature: ", #temp, CR, LF )
' Calculate First Digit
if temp < 100 then
let math_dump = loop_dump+10
if temp >= loop_dump AND temp < math_dump then
let digit_1 = loop_dump/10
exit
let loop_dump = loop_dump+10
loop while loop_dump <= 100
let loop_dump=0
let math_dump=0
let digit_1 = 10
let loop_dump=0
let math_dump=0
' Calculate Second Digit
if digit_1 != 10 then
let math_dump2 = digit_1*10
let math_dump2 = temp - math_dump2
if math_dump2 = loop_dump then
let digit_2 = loop_dump
exit
loop while loop_dump <= 9
let loop_dump=0
let math_dump=0
let digit_1 = 9
let digit_2 = 9
let loop_dump=0
let math_dump=0
' Digit 1 Buffer
get digit_1, digit_1_buffer
' Digit 2 Buffer
get digit_2, digit_2_buffer
' Display each digit 500 times (takes 1 sec approx)
' Display First Digit
high portc 2 ' Digit 1 On
low portc 1 ' Digit 2 Off
outpins = digit_1_buffer
pause 1
outpins = %00000000
low portc 2 ' Digit 1 Off
high portc 1 ' Digit 2 On
outpins = digit_2_buffer
pause 1
outpins = %00000000
loop while loop_dump < 500
let loop_dump = 0
let math_dump = 0
Goto Top
