I haven't seen one of these on here for a while so I thought I'd share mine......
I'd rather be sitting down to a cup of coffee than standing over a shallow dish rocking it backwards and forwards for 15 min You pays yer money etc etcNice work, but is it really necessary? You write that it can take 15 minutes, isn't that very long if you are using the air pump?
You are welcome sir.Steve, that looks very practical for occasional use. I'll look back at your project when I start mine. Thanks!
I've actually found this process to be an effective aid to Zen meditation, and rather enjoy it.I'd rather be sitting down to a cup of coffee than standing over a shallow dish rocking it backwards and forwards for 15 min
Thank you for the info.... just ordered it.@SteveT
re. the comment in your pdf about a 35°C heater,
this one, according to the product description
appears to achieve that.
http://www.amazon.co.uk/SuperFish-Nano-Heater-Length-0-50L/dp/B0050BY5BY/ref=sr_1_1?ie=UTF8&qid=1345401596&sr=8-1
I'm sure that there are others.
e
Oxalic acid £2.89 + postage from ebay (or £19.00 from rapid) for 1kg - removes ferric chloride stains from worktops floors and clothing. Good for rust stains as well.The concentration lapses over a fifteen minute period and the shallow dish has a tsunami effect on the light coloured kitchen worktop, with the inevitable bright yellow stain to explain away to the OH. Buy the air pump, it could keep you out of a lot of domestic grief and recriminations.
I've got rheumatoid Arthritis so 15 min on my feet would have me screaming in agony, still, keeps the local kids away from the doorI've actually found this process to be an effective aid to Zen meditation, and rather enjoy it.
A long straw will do as long as you blow and not suck, you dont even need a flow rate at all if you suspend the board vertical away from the edges, as for a heater i just use a bucket of hot tap water to sit the container in, also serves as washup water after.What flowrate is enough to etch the pcb ?
lmao nearly wet myself (ala uncle albert and the lion in the jungle) when I read that"What flowrate is enough to etch the pcb ?"
- dunno, but mine (Mega) bubbles like mad and buzzes like an Anne Summers party.
