Blimey, three days.Just soldered up a small stripboard for a 556 circuit - then noticed that I had used a 16-pin DIL socket
So why can't you just put the 556 in the socket with the bottom two pins on the socket unused?Just soldered up a small stripboard for a 556 circuit - then noticed that I had used a 16-pin DIL socket
So why can't you just put the 556 in the socket with the bottom two pins on the socket unused?.
Have you already cut all the tracks with the stripboard cutter?Because, like a complete fool, my mind switched to counting pins from 1 - and as there were 8 pins on each side nothing is in the correct place
Oh, yes - it is a 25p piece of toast (rescued everything but the socket and a 1K resistor).Have you already cut all the tracks with the stripboard cutter?.
