Jolie Brise
I built a basic circuit sucessfully using a slotted disc sinking a red led and sourcing a green led from pin1 to check it was working.
I now want to add a counter on pin2. Tried simple b0 = b0 + 1 but it did not work. So I put an orange led on pin2 to check if it was going high when pin1 went high.
if pin4 = 1 then high 1
elseif pin 4 = 0 then low 1
if pin 4 = 1 then high 1,2
elseif pin4 = 0 then low 1
This did not work.
I tried changing the code by adding elseif pin4 = 1 then high 2
All leds on when loading the programme. Both red and green on permanently.
How do I get output pin2 to go high when input pin4 goes high.
Tony
