I have a 4N25 optocoupler and I want to use the PWM function of the picaxe to drive it. The 4N25 would be switching an IRF 530 supplying a largish motor (24V 5A).
How do I work out if the 4n25 can switch fast enough. All I can find on the datasheet is the non saturated turn on/off time. This is 2 micro secs, so can I assume the opto can deliver a duty cycle of 4 micro secs? At 4mhz I think the duty cycle on the picaxe is 26 micros secs, so I assume this is no problem.
Then I need the opto to switch fully on/ off, how do I do it with this device?
