Hi i was just after some advice with regards to the osc protocol and its compatibility with a picaxe. I have read up on the protocol and from what I can make of it the touchosc app pumps out float32. So my question is do I need a maths coprocessor to read this data stream into a picaxe. I can already recieve the data over udp into the picaxe as variables but cant make sense of the slider data being sent which is a 0-255 slider. If the data was being sent as integer there would not be an issue hence the maths processor idea to convert the data on the fly.
Thank you in advance
RICH
RICH
