OLED serial code.
shamu
Hi all.
I am using an AXE13Y that is fed a message from an 08M2 to display a SIRC code received via infrared.
Now I'm not proud of this but my code looks like:
'  This program loads into an 08M2 and takes an infrared input on pin 6 then outouts
' it's SIRC value to on OLED conected to pin 7.
#picaxe 08M2
#no_data
SYMBOL infravalue = b10 ; define an infra variable
'let dirs = %10111111  ' Set port C as all outputs.
init:
pause 500
irin C.1, infravalue ; read input C.1 into infravalue
if infravalue = 1 then
 'serout C.0,N2400,("SIRC Code:   ")
 serout C.0,N2400,("SIRC Code: 1")
if infravalue = 2 then
 serout C.0,N2400,("SIRC Code: 2")
if infravalue = 3 then
 serout C.0,N2400,("SIRC Code: 3")
if infravalue = 4 then
 serout C.0,N2400,("SIRC Code: 4")
if infravalue = 5 then
 serout C.0,N2400,("SIRC Code: 5")
if infravalue = 6 then
 serout C.0,N2400,("SIRC Code: 6")
if infravalue = 7 then
 serout C.0,N2400,("SIRC Code: 7")
if infravalue = 8 then
 serout C.0,N2400,("SIRC Code: 8")
if infravalue = 9 then
 serout C.0,N2400,("SIRC Code: 9")
if infravalue = 10 then
serout C.0,N2400,("SIRC Code: 10")
if infravalue = 11 then
 serout C.0,N2400,("SIRC Code: 11")
if infravalue = 12 then
 serout C.0,N2400,("SIRC Code: 12")
if infravalue = 13 then
 serout C.0,N2400,("SIRC Code: 13")
if infravalue = 14 then
 serout C.0,N2400,("SIRC Code: 14")
if infravalue = 15 then
 serout C.0,N2400,("SIRC Code: 15")
if infravalue = 16 then
 serout C.0,N2400,("SIRC Code: 16")
if infravalue = 17 then
 serout C.0,N2400,("SIRC Code: 17")
if infravalue = 18 then
 serout C.0,N2400,("SIRC Code: 18")
if infravalue = 19 then
 serout C.0,N2400,("SIRC Code: 19")
if infravalue = 20 then
 serout C.0,N2400,("SIRC Code: 20")
if infravalue = 21 then
 serout C.0,N2400,("SIRC Code: 21")
if infravalue = 22 then
 serout C.0,N2400,("SIRC Code: 22")
if infravalue = 23 then
 serout C.0,N2400,("SIRC Code: 23")
if infravalue = 24 then
 serout C.0,N2400,("SIRC Code: 24")
if infravalue = 25 then
 serout C.0,N2400,("SIRC Code: 25")
if infravalue = 26 then
 serout C.0,N2400,("SIRC Code: 26")
if infravalue = 27 then
 serout C.0,N2400,("SIRC Code: 27")
if infravalue = 28 then
 serout C.0,N2400,("SIRC Code: 28")
if infravalue = 29 then
 serout C.0,N2400,("SIRC Code: 29")
if infravalue = 30 then
 serout C.0,N2400,("SIRC Code: 30")
if infravalue = 31 then
 serout C.0,N2400,("SIRC Code: 31")
if infravalue = 32 then
 serout C.0,N2400,("SIRC Code: 32")
if infravalue = 33 then
 serout C.0,N2400,("SIRC Code: 33")
if infravalue = 34 then
 serout C.0,N2400,("SIRC Code: 34")
if infravalue = 35 then
 serout C.0,N2400,("SIRC Code: 35")
if infravalue = 36 then
 serout C.0,N2400,("SIRC Code: 36")
if infravalue = 37 then
 serout C.0,N2400,("SIRC Code: 37")
if infravalue = 38 then
 serout C.0,N2400,("SIRC Code: 38")
if infravalue = 39 then
 serout C.0,N2400,("SIRC Code: 39")
if infravalue = 40 then
 serout C.0,N2400,("SIRC Code: 40")
if infravalue = 41 then
 serout C.0,N2400,("SIRC Code: 41")
if infravalue = 42 then
 serout C.0,N2400,("SIRC Code: 42")
if infravalue = 43 then
 serout C.0,N2400,("SIRC Code: 43")
if infravalue = 44 then
 serout C.0,N2400,("SIRC Code: 44")
if infravalue = 45 then
 serout C.0,N2400,("SIRC Code: 45")
if infravalue = 46 then
 serout C.0,N2400,("SIRC Code: 46")
if infravalue = 47 then
 serout C.0,N2400,("SIRC Code: 47")
if infravalue = 48 then
 serout C.0,N2400,("SIRC Code: 48")
if infravalue = 49 then
 serout C.0,N2400,("SIRC Code: 49")
if infravalue = 50 then
 serout C.0,N2400,("SIRC Code: 50")
Surely there must be an easier way to display the content of a variable, something like:
serout C.0,N2400,"SIRC value is:";infravalue
Thanks.
jims
This should do what you described. Be aware that data from the numeric keypad. is offset & may need to be corrected if you want it to match the symbols on the keys. Jims
#picaxe 08M2
#no_data
init:
pause 500
	 serout C.0,N2400,(254,1)
	 serout C.0,N2400,(254,128,"SIRC Code:   ",#b10)
	 pause 1000	'Pause to see OLED.
