I have a Picaxe circuit I have designed for a car again. It was working very intermittently and starnge. Only difference this time is for example instead of triggering INPUT 1 to ground through a npn transistor, this time I just put pin 1 directly to ground through a 1n4004 diode. I don't think it liked that. Should I have used a resisitor to go through as well. Because now the circuit does it's routine but completely ignores my input 1 completely. Bugger it! What value resistor does someone recommend. 10k sufficient enough or to high. I have my 10k Pull up in the circuit by the way. Obviously the Diode was not enough. It's a dead Picaxe is it not. Can still program it etc but the input 1 no longer does it's job. It was working but extremely unreliable. Any advise anyone.
Â
Â
