parts-man73
I just recently started having problems downloading to my 18X chips. I can check the firmware via the "options..." menu. I can also "clear hardware memory" without errors. But when I try to download a program, it errors out with a "memory verification error at byte ???"
The possible causes it lists are
1.Cable removed during programming
2.Power removed during programming
3.incorrect power supply (e.g. 6V) used
I obviously am not removing the power or cable during programming. The power supply I am using is a wall wort that is providing 5 volts. I've checked with my digital multimeter and I find 5.2 volts on pin 14
If I press the reset button (pulling pin 4 low) and release the button at the same time I start my download, it will take the program. But if the program is too large, it will error again, but at a higher byte. (the error code displays the byte at which the memory verification error occurred) So I can never load really large programs.
The only thing I can think of that is different, is that I am using a different computer now, maybe the serial port isn't compatible. It is a desktop computer, I know some have had problems with laptops.
I haven't tried this yet, but should I try using a MAX232 in my download circuit? I don't have any suitable transisters in my supplies to handle the inversion nessesary for this chip, but if need be, I can get some monday when my local electronics store opens.
Thanks,
Brian
Thanks,
Brian
