trevorboultwood
Hello every one, hope every one is enjoying the Christmas build-up!
Well as I am waiting to receive my LED matrix's I have decided to start using up all of my discrete IC that were the first type of chips i ever bought. Included in my collection was a couple of a 4017 decade counter. Very smart chip in my eyes .
Any way after soldering it to a strip board it worked first time (after miss placing the Bargraph array 3 times :L) At the moment there is just a wire sticking out just to test it for a while (will remove it don't worry ) . Well it's nice to see how static can keep clocking the chip after rubbing your foot against the floor :L. Any way the small little problem I am having is now attaching a little button to clock on the pin. I have a small idea on how it works and i know it has to be connect to the ground and then the +. I have a switch but when ever i try it just mucks up. I know I am doing some thing wrong because I have just been guessing so far.
Here is what I have tried. Connecting the pin to ground with a resistor to keep it low. I then have a switch that when pressed makes the clock go high. For some reason this didn't work. ( I will attach a picture to show you the setup.) I can make it work with a relay if needed as i bought some tiny 3volt relays. But is there an easier way?
Thank you all for taking a look And this is just a side project to keep me occupied for the led matrix's to come.
(Just managed to do it with a simple relay circuit, but there must be an easier way?)
