davehouston
I'm totally new to PICAXE but have a bit of experience with PICs and AVR.
I'm developing a Home Automation system (as well as general purpose hardware) using Arduino form-factor PCBs with a combination of AVRs (using ZBasic) and PICs (using PicBasicPro/ds30 loader).
The distributor who will manufacture/distribute these has a very open sores, educational philosophy so I am exploring using PICAXE chips both on the above referenced shields and on the system boards.
I've done some preliminary reading of PICAXE literature but have additional questions that I hope the folks here can answer.
Are there datasheets that detail the amount of memory and register addresses for the newer PICAXE 8, 14, 28 & 40 pin chips? Are they cross-referenced to the underlying PIC model?
Since PICAXE 8 & 14 pin chips cannot be I2C slaves, I'll need to manage the same function via peek/poke, bit-banging. Is this possible? Could the approach used in the PBP code in post #7 to this thread work with PICAXE?
I need to handle both IR and RF input/output but cannot be limited to what PICAXE supports. For output I need to generate both the carrier (~38kHz) and data envelope. I am assuming I can use PWM and high/low/pauseus for these. Do you forsee any problems?
For RF/IR in, I need to capture the time between rising edges and I see no native methods for this. Is it possible to access the capture/compare hardware using peeksfr/pokesfr?
