Mad Professor
Good day all.
I hope you don't mind me posting a non-picaxe related question.
I am trying to design and build a serial interface cable to connect my PC or laptop to a control board.
The control board in question has 6pins on the serial connection.
Pin1 - (RxD Positive).
Pin2 - (RxD Negative).
Pin3 - (TxD Positive).
Pin4 - (TxD Negative).
Pin5 - (Ground).
Pin6 - (+12 Output).
Looking at the control board Pins1&2 are connected to a CNY17-3 Optocoupler via a 100R resistor.
Using my scope, when the control board is 1st powered on Pins3&4 have a 0-12volt pulsed signal output, for about 10sec.
I also scoped the voltage range of the com-port on my pc, and it swings from -12 to +12volts.
I have not worked with serial hardware much.
Can anyone here please advice how I should go about designing and making this opto-isolated serial interface cable?
Thanks for your time.
Best Regards.
Pin5 - (Ground).
Best Regards.
