I have recently purchased a 40X1 and am now trying to get the chip to link up with my computer. I have configured the circuit as shown in the diagrams with the 22k and 10k resistors tied to the serial in. I have also connected the 4.7k resistor to the reset pin with the reset switch set high. I am using a regulated 5V power supply and have checked all the connections that I have made on the bread board. I also have made sure that I am using the correct communications port.
When I tell the computer to run the program it attempts to connect with the microcontroller and I have watched the voltage on the input change from low to high. I have not been able to measure a response from the serial out pin on the controller though.
Any help with this would be greatly appreciated, Thanks.
