I would like to relate a experience I just encountered using latest programming software. I have a good stock of 18x's and use them for most of my projects. I am building a new project and when I went to program the 18x it would not program! I tested the programming cable, reloaded the drivers for the USB to serial converter, re-installed the editor,changed the comm. port, changed 5c supply etc. and checked the wiring many times and all without success. I even attempted to clear the memory on working 18x assemblies and could not alter them in any way!
I scanned the posts on this great forum and found a post talking about programming an 18x at 3.3vdc. I replaced the 5vdc. supply with a 3.3vdc. supply and all went well, I then tried the 5v again and again NO success!
I spent many hours trying to find the problem thinking it was my actions causing this problem.
All my 18x'x were previously programmed at 5v ( with the older editor) and no problem was ever encountered. There is no problem with the 5v supply and all my projects are working fine using this 5v supply.
I can only conclude that the new editor has a problem with 18x's. There is
a note stating the 18x is being replaced with the 18m2.
Am I incorrect about the new programmer not liking the 18x?
Is the older version editor available?
Thank-Earl
Thank-Earl
