need help please
jyb
hi all
i wrote a simple program to drive a stepper motor behind a "leadshine" driver
a simple switch to give the direction rotation and a potentiometer to drive speed between 30rpm to 800 rpm
for gain speed a short loop is used
what i want is to change cpu speed clock setfreq m8 at motor start and when launched, change to setfreq em64.this is done using comsetup and setintflags
at begining potentiometer rise up with low speed and passing over a threshold , freq is siwtched to 64mhz
it don't run correctly
there is something i misunderstood but what?
here is one example of tens tests i tryed
perhaps somebody could help me?
thanks
pic18f45k22
#picaxe 40x2
setfreq m8
symbol compvalue_ = b2
symbol potentiometre = w0
symbol pulse = c.2
low C.6
adcsetup = A.1
'9876543210 76543210
compsetup %0010100010,%10011110
'flags mask
setintflags %00010000,%00010000
compvalue = 0
marche:
readadc10 A.1 , potentiometre
pulsout C.2 , 1 pauseus potentiometre 'debug'sound A.0,(100,50)
goto marche
interrupt:
setintflags off
if compvalue > 1 then setfreq em64 else setfreq m8 endif 'debug
Can you post a circuit diagram of your hardware and also explain exactly what does not work as expected.
jyb
mill machine help
here is joined the drawing
what i want to do is at the starting motor state the setfreq is 8mhz, and when potentiometer begin to move , and once motor is running very slow , an interrupt is generated on programmed potentiometer level and system clock is switched to 64mhz permiting higher speed to the stepper motor
(no pwm needed, just only pulses frequency variation)
the little program previously joined is to find best solution for lower and higher speeds but it locks in beginning phasis and i can't undersand why
i think the problem is using compsetup and setintflags , something i misunderstood ?
thanks
You do not appear to have attached the circuit diagram and it is hard to see what the code should be without that.
The two most likely issues it seems to me, beyond COMPSETUP configuration error, are the PICAXE prematurely entering interrupt or continually entering interrupt.
Does the code work as expected when interrupts are not used ?
There appears to be an issue with COMPSETUP which we are investigating.
In the meantime you might be able to work round the issue by testing the pot value rather than interrupting. You may need to adjust the value of "K" -
#picaxe 40x2
symbol K = 256
  setfreq m8
    pulsout C.2 , 1
  loop until potentiometre > K
  setfreq em64
    pulsout C.2 , 1
  loop until potentiometre < K
Jamster
Another error is that you require a colon in the second last line.
#picaxe 40x2
setfreq m8
symbol pulse = c.2
low C.6
adcsetup = A.1
'flags mask
compvalue = 0
marche:
readadc10 A.1 , potentiomet[COLOR="red"]er[/COLOR]
goto marche
interrupt:
setintflags off
if compvalue > 1 then setfreq em64 else setfreq m8 [COLOR="Red"]:[/COLOR] endif 'debug
also work on spelling is required ;)
#picaxe 40x2
goto marche
QUOTE]
My understanding is that the need for a colon is (unfortunately) not correct.
While the manual 2 does state:
Newline
Commands are normally placed on separate lines. However if desired the colon
(:) character can be use to separate multiple commands on a single line e.g.
if pin1 = 1 then : high 1 : else : low 1 : endif
As a matter from past history, I believe that Rev Ed have included within the PE the capability of having a space as an alternate separtor.
Sloppy coding IMHO as it then adds a further complexity for those helping to be sure where a new line functionality is intended.
jyb
hi jamster
#picaxe 40x2
setfreq m8
symbol pulse = c.2
low C.6
adcsetup = A.1
'flags mask
compvalue = 0
marche:
goto marche
interrupt:
setintflags off
does quote change anything when program run?
