Hi there, I need a circuit and code fully designed for a home project. I am willing to pay via PayPal.
Required Functions:
Optional Functions:
I currently have the following components available:
Thanks a lot, please reply here or pm me if you're interested.
Required Functions:
- Read the temperature in degrees C.
- Display the temperature on a two digit, common cathode, multiplexed seven segment display.
- Three temperature thresholds; lower, middle, and higher.
- Turn off 12v fan when temperature falls below the lower threshold.
- Turn on 12v fan when temperature rises above the lower threshold.
- Sound an alarm when temperature rises above the higher threshold.
- On/Off switch.
Optional Functions:
- Menu for user to define threshold values.
- DS18b20 Thermometer
- Picaxe 28X1
- Double-digit common cathode seven segment display
- 5v voltage regulator
- 12v fan
- Buzzer
- On/off switch
- Several push-to-make switches
- 50k variable resistor
